Re: Engine reving up on turns and straight running
It sounds to me that your problem is more likely cavitation and not ventilation. The fact that the anti ventialtion plate is below the keel and your still having issues is a big red flag that your problem may not be ventilation. I've never installed a suzuki but I do speak to evinrude and yamaha application engineers on a fairly regular basis and they always stress that the anti-ventilation plate should never be below the keel; it should be in line or up to 1 inch higher. The higher the engine is mounted the more efficiently it will operate, as long as its not ventilating. I'm sure the suzuki engineers would have the same advice. (I certainly don't represent any of these manufacturers, I'm just relaying info from my conversations with them)
The next red flag is the extremely low rpms. This tells me that the prop is experiencing such excessive loads that it will not allow the engine to come anywhere near its correct operating rpm. These extreme pressures on the face of the blade can actually cause the water to "implode", or cavitate, and this is when the engine will suddeny start reving as if it was "ventilating".
First thing I would do is to inspect the face of the prop very carefully. If you notice very small pitts in the surface of the metal, then I would say you are definately cavitating. If you don't see them, it may be due to the fact that you have very few hours on the engine/prop and doesn't necessarily mean that there is no cavitation occuring.
I would then try switching the prop out but I would not step all the way down to a 13" pitch. I would start at 17" and see what happens. If the problem is resolved, I would then bring the motor back up untill it is at least inline with the keel. Then, if needed you can try a lower pitch prop to dial in your WOT rpm.
Prop issues can be sort of mysterious black magic, although there is some science behind it, when it comes down to it you just have to experiment.
Good luck and keep us posted, I hope that the info I have provided can help.
and someone please correct me if I mis-stated something, there's always more to learn!
