engine rotation question/inboard
kevincave
i searched and had no luck. my boat has a mercruiser engine designated mie 330, which in the manual says is an inboard motor. also says all mercruiser in/out run counter rotation, inboards can be either way. on the original air cleaner it has the counter rotation firing order, now the engine has been upgraded to a 1992 330hp gm marine engine. i am new at inboard motors so please have patience.. i dont understand how the counter rotation works. i see the firing order reversed but what about starter? does it spin oppisite direction also? i also dont understand the difference between in/out and inboard motors. i understand automotive engines just fine and have built several. this has me kinda stumped. help would be greatly appriciated. thanks...kc
Bt Doctur
Re: engine rotation question/inboard
What type of transmission or drive is on the boat?
standard firing order 1,8,4,3,6,5,7,2 .Is this what you have on the aircleaner?
Most single inboards and inboard/outboard motors are standard rotation.
The starter rotation depends on aft entry or block mounted.So if you have a standard motor with aft entry you need a reverse rotation starter ,same motor with a block mounted starter you need a standard rotation starter.
Reverse rotation motor with a aft entry uses a standard starter, block mounted uses a reverse rotation starter.
kevincave
the firing order on the cover is12756348, upon further investigation it also say rh rotation. starter mounts to the block. standard rotation would be Lh? trans is a volvo penta 280
