Engine run on
jack52559
Is it possible for water to get sucked into the engine if the engine runs on after turning off with the key?
riverratjody
Re: Engine run on
Not only possible, but probable. Dieseling will cause the engine to run backwards. I'm assuming you have through the prop exhaust. Happened to me. My fix was to start using Hi-test gasoline and to allow the engine to cool down by idling a few minutes before I shut her down. Worked for me.
180shabah
Re: Engine run on
Yes it is possible. You need to look at several things like, timing, idle mixture, idle speed, heat range of spark plugs, carbon deposits in combustion chamber and procedure (ie proper cool down time). It should not be necessary to run premium gas - it only adds to the deposit problem.
Re: Engine run on
Ayuh,... I answered this question over Here...
achris
More fish than mountain goat
Re: Engine run on
Let me guess.... Mercruiser V6 4.3 litre with a Weber 4bbl carb, yes?
Chris........
achris
Re: Engine run on
So why is he asking again? Maybe it's because he don't trust ya! Or maybe it's like they say about doctors advice, always get a second opinion?.... :D:D:D
Sall right, I trust ya, Bond-o.....
C........
Re: Engine run on
Ayuh,.... Sail,..?? Sail,..?? There Ain't no danm Rags hangin' off Any of My barges....:eek::p:D
Some of them had Weber carbs......
Yep,... The Leaky 1s, like Mine....:rolleyes:
