Engine run rough on idleing, stall when put in gear -
BajaFishin
Hi,
I have a 95 Force 120hp, on a 95 Trophy 2002.
I added 3 cans of sea foam, with full tank of fuel, do you think this might be the cause of Engine runs rough on idling, stalled when put in gear?
What does it do? I thought It suppose to be good.
TIA for any input -
Baja
eurolarva
Re: Engine run rough on idleing, stall when put in gear -
how much gas are you guessing was in the tank? Check out your spark plugs and see if they are fouled. The quantity you are using the seafoam will act like a decarb and tends to foul plugs.
