usernamesrule
Thread starter- Joined
- Apr 17, 2010
- 8
It's a 1997 25 hp Evinrude. It's been running pretty poorly lately. I replaced the plugs(Champion QL77JC4) and the wires(one was bad). Only the bottom piston is working. I know this because I started it yesterday with only the bottom plug connected to the plug wire. The spark plug was in the block, just not connected.
Basically, the engine runs exactly the same whether the top plug is connected or not.
Other details: I took out both plugs and turned it over. From the steering wheel(where I turn it over), I can see gas vapor coming out of the top piston, but not the bottom. This seems odd because it is definitely the bottom piston that works. I put a paper towel over both open pistons and turned it over, and it looked like both were ejecting gas onto the paper towel.
Also, I plugged a little inline light into the spark plug wire. It blinks when the plugs are recieving the current. It blinks the both on the same.
I'm not sure what all of this tells me. Seems like both pistons are getting gas and spark. Could the top piston be getting too much gas? I do have to have the throttle up pretty high to make the engine start(on just the bottom cyl).
Thanks for you help guys.
