Engine runs but.....
waterwezl
Got the engine running like a top but I'm not sure if the points and spark plugs are gapped correctly. It's a 230B Volvo I4 and it runs strong but I want it set up right before I tear into the floor repairs. Also is there supposed to be a primer bulb between the fuel tank and the engine driven pump. I only ask because somebody cobbled together a fuel line and there is one in the line with NO fuel filter.:confused: Thanks.
Robj
Re: Engine runs but.....
Plug gap .028''
Points gap .016''
Dwell 62 degrees +/- 3 deg
No there should not be a primer bulb in your fuel line. Remove the line and replace it with USCG approved fuel line.
Have a great day,
Rob.
ccmarsh
Plug gap .028''
Points gap .016''
Dwell 62 degrees +/- 3 deg.
Could you please explain what all that stuff means. Recently I pulled all my spark plugs and cleaned them up but I just put them back in. what does all that stuff mean?
waterwezl
Thanks a bunch. Gonna put it on a sticker somewhere in the engine compartment so I don't forget it.
