justinteoc
Thread starter- Joined
- Jul 24, 2013
- 51
I have a 97 3.0 GSMLKD and when I purchased the boat last year it did not have a thermostat installed so after reading that it does need one I purchased one and installed it we'll at cruising speed the temp will continue to rise and when I come to idle it will sloooowly return to normal and if I remove the thermostat it will only run about 110 even a wot. I have replaced the manifold but not the riser and the riser is not completely stopped up but I can tell it's kind of stopped up but if it's running cool without T'stat wouldn't that tell me it's not a riser restriction? Also the T'stat is a Sierra not oem but it is working correctly? The T'stat housing is a little rusty but not bad enough to be restricted.. So I'm lost I'm thinking about just leaving it out and stop worrying about it......
Also it has a brand new sea water pump and it is definitely timed perfect..
