engine serial starting with a
boatermarquis
140 hp mercruiser 3.0,engine serial a339876,outdrive a338939,I need head gasket kit,not for sure witch one to get.
achris
More fish than mountain goat
It's not the same. The Merc part number in that kit is 27-53354, the one you need is 27-96429... And the earlier one does not supersede to the later...
boatermarquis
when i looked up serial cant find it anywhere,what year is it,i know the guy did work on it.
boatermarquis
I've never ordered from here,wondering how you found that from the serial number,i cant locate on any sites.boat is 85,not forsure if motor has been swapped before,do they have overhaul gasket kit?
Fun Times
MERCRUISER - (140 H.P. (1985) Serial No: 0A339876 Model No: 01409005 Parts Catalog No: 90-41261. http://www.mercruiserparts.com/selec...?doc_nbr=41261
Outdrive serial number 0A338939
Are you sure that's the correct serial number for the stern drive? It's coming up as an MERCRUISER 120 H.P engine. Either way being an 1985, this parts catalog will work for your stern drive for part number look up. http://www.mercruiserparts.com/selectSerailRange.asp?doc_nbr=R/MR/ALPHA+ONE+(Sterndrive)+1983-1990
boatermarquis
hey thanks,i wrote down the wrong outdrive number,If was just wierd all the charts i seen had none that started with a A.
