engine side fuel connector
vwluv32
Just finished the fuel pump conversion on the'57 18hp(F R's way) and I'm not really happy with the connector I came up with to connect the fuel on the engine(limited choice on a sunday @wally world). Whats a good way to go with this? Pics would be wonderful!!
Thanks,
Chris
kbait
Re: engine side fuel connector
Sounds like you're looking for the connector on the motor side that the hose connector hooks to. I believe a single line connector from 1961+ will bolt right to where you removed the 2 line connector. Tim's outboard will have a used one 218-682-2331, or spend more and get a new one. You can find the brp item number by going here and searching '68 18hp.. It will be the one you need: http://epc.brp.com/login.aspx?ReturnUrl=/Default.aspx&AspxAutoDetectCookieSupport=1 Can't promise that a new one will be available.
