OneLuv1979
- Joined
- May 25, 2009
- 88
OK my boat motor is a 2003 Johnson 115hp 2 stroke with oil injection ...
I just had the lower unit sealed so im pretty sure its not the lower unit ..
Anyhow i took the boat out for the 1st time and it ran good smoked alot figured its the nature of a 2stroke but it continued to smoke over the 3-4hours of it running ...
BUT it did run good , when i got it home and i was flushing it , i decided to start it and let it idle for a few minutes and when it started, it began spraying oil out the prop all over my gargae door , i let it run for about 15-20sec then shut it off and the prop had oil in the center and oil running down the unit ....
My logic tells me the VRO pump is not properly pumping or could even be cracked causing it to run lean ? BUT im no boat mechanic and figured i better ask someone with more knowledge then me , maybe im way off , what you guys think ?
