Well...here was my plan -I was going to take the boat out for a quick ride than come back in and pull the boat out on the trailer take it home - winterize and cover it. I started out and got about 5 miles from my dock on a plane when I noticed the temperature falling down to 120 degrees on the starboard engine then slowly the boat came off a plane and the starboard engine died. I have 4.3 MPI Mercrusier Alpa-II open the engine hatch and on the front of the starboard engine there is a plug in the intake manifold with a pin hole in the center of it spraying salt water everywhere like old faithful. The engine will not start. So I have to go back to the dock on the port engine (no power steering). I have just enough time to pull the boat, winterize it and cover it before I had to leave to go back home (3 hour ride). I did not get a chance to look at the engine - I did spray it down with Boeshield. The air cleaner/cover was soaked with water. There was no water in the oil. I will be going back this weekend to try to get it running and replace that plug (getting that plug out could be a problem -its got a square slot in it smaller than a 3/8 extension but bigger than a 1/4) . I am hoping the distributor cap got wet and killed the engine??
Any suggestions would be great
