New guy here.
I have a 2010 Mercury Optimax 90 2 stroke that will not allow me to run WOT. As the boat begins to plane the engine starts sputtering. It appears that this happens around 3000rpm. I have had the motor checked over several times to no avail. Fuel & air pressure are good. No water in fuel and again fuel is being delivered adequately and properly. Motor starts and idles with no issues it's only when trying to run WOT. Last mechanic stated that he believes it is electrical. Changed the plugs recently and ensured all boots were secured properly, check fuses (I could see easily) and tried to ensure all grounds were tight (again the ones I could see). I have had the injectors cleaned and flow tested, fuel lines are all new as well. I'm at a loss, mech said the motor works fine it's something is cutting out and not allowing the engine to run WOT. I have video of it as well.
Any ideas/suggestions would be greatly appreciated.
Engine S/N - 1B736961 I
Thanks,
Chad
Thanks,
Chad
