Halstead666
Thread starter- Joined
- Jul 23, 2014
- 19
I have a 96 mercruiser 5.7 alpha one. The engine runs good although one problem persists.....after running the engine with load for a typical 20-30 minute cruise to a given destination @ 2500-3000 rpms when arriving at the destination I need to baby the throttle otherwise the engine will stall.....If I run down to 1000 rpms it usually will stall out so I have to slowly run it down for about a couple of minutes to avoid the stall seems like the gas in the bowl is not able to burn off from a quick downshift and the egine floods itself ......it is mostly a problem when towing tubes/ skiers when there is the need to slow down or stop quickly. Not sure if this is just normal operational procedure or if I have a problem that needs a fix? Thinking maybe the float is off? Any suggestions on what might need to be looked at? Thanks
