Re: Engine stalls under rapid full throttle
I would have to vote for accelerator pump possibly an improper float adjustment along with it. <br /><br />Why was the timing way off? Timing just doesn't get off unless something is broken, or it has been monkeyed with. Before trying to get the carb fixed or anything else, get that distributor checked out. Why didn't the mechanic work at it if he thought it was bad? And a better question, why would it be stuck if it will turn to adjust? <br /><br />If timing is off possibly the advance is not working properly too. I have seen a few stuck in advance making the timing hard to set. <br /><br />Get the distributor checked first, then go to carb assuming all other circuits are good (plugs, wires, rotor etc.)<br /><br />Good luck and let us know.
