Engine starting problem, water in fuel and warning buzzer
Gpag
I had trouble starting my motor yesterday. Once it started it seemed to run ok, got on plane no problem, plenty of power. However, if it sat for a while it was hard to start again. I dumped the fuel from the engine fuel filter into a container and also drained fuel from the Racor water separator into a container (photos). Looks like I have water in my fuel tank. I am located in Yarmouth, MA where we just had two tornados touch down and torrential rains. I don’t think it has ever been done (2003 boat) so tomorrow I am going to replace the o-ring on the fuel cap. How do I deal with the water that is there? It is a 104 gallon tank with about 75 gallons in it. I’m considering trying to pump out the water through the fuel sensor hole but, when I tried to remove the sensor to replace it I couldn’t budge it. I was afraid of breaking something.
Also, When I was trying to start the engine I got a buzzer that kept up while the key was turned and the engine did not crank. After a few tries the engine did start for a second or two and then died. In those instances the beep was a very short one when I turned the key. Eventually the engine started.. The photo shows the chart from the owners manual for a warning buzz. It doesn’t say anything about water in the fuel. There is plenty of oil and the engine never dropped rpms when running and I never got a beep when running. So I assume lack of oil is not the problem. There was good water flow out the tell-tale so lack of cooling shouldn’t have caused a warning. Would water in the fuel cause the warning beeps? The service manual doesn’t say anything about what the warnings mean. I just want to make sure I don’t miss anything.
Bt Doctur
Working on a customers 115 FI .Original complaint was that it quit running , would start then stop, etc. Found the engine mounted filter that you could not gently blow air thru and 3 of the 4 injectors with 18% flows. and no debris but a tablespoon of water . Replaced all filters, repaired injectors, and a test run done, boat returned to customer
After a days running the stalling problem returned. Boat sat overnight and a test run performed in the morning and was flawless except the engine mounted filter was getting plugged up again? Primary water sep had nothing but the engine one had 1/2 a teaspoon of water .
Pumped a 1/2 gallon of fuel thru the filter sep and got about 2 tablespoons on water . Now the good part, After mixing up this 1/2 gal it took almost an hour to re-seperate.and appear on the bottom
Now can water molecules in fuel go thru a standard water sep and clog up a 10 micron engine mounted filter to restrict the fuel
Would a filter with the plastic bowl show this instead of the standard spin on?
