Re: Engine starting problem
Sounds like it's time to take it to the shop.<br /><br />You've posted multiple problems here in other post and while we are all happy to help, sometimes you have to spend that $50 to have a professional diagnios what's wrong with your engine.
<br /><br />But, to address this post;<br /><br />1) Did you check the battery, (a battery dump test)<br />2) Did you check each cell for proper water level<br />3) are all of your battery connections clean, ( positive and negative )<br />4) are the batteries new and fully charged<br /><br />If its not the batteries, or the wire connections, then you need to look at the starter and solenoid. I replace my solenoid every 2 years as preventive maintenance.<br /><br />You can pull your starter and take it to Napa, Auto Zone, etc., and they will bench test it for you.
