tazzerblue5
- Joined
- Aug 6, 2018
- 26
Will this bolt right in a 1996 Maxum? I would be replacing the outdrive also. The 4.3 block cracked. Just curious if the hull is made for a direct fit for the engine mounts. Thanks.
If you don't yet have the V8 go for the 5.7L. Vortec heads preferably. Even in a 19' boat the 5.0L is way underpowered.
Maxum is a 190, 19' model.
The Maxum 19's always had V8 options so motor mounts should be a non-issue. The outdrive needs to be either 1.47 or 1.50. You can either install a 1.47 upper gear set, find a good used/new 1.47 upper, or find a good used/new 1.47 complete outdrive. The gear set you can find for about $178. I just did one. eBay has lots of options for swapping the drive/upper. Other than that the engine swap should be pretty straightforward.
