Engine Swap Question
Starcraft Enterprise
Re: Engine Swap Question
Here is an idea. What if I take the volvo flywheel that is on the 350 to a machine shop and have it centered, re-drilled and balanced to accept the mercruiser coupler.
Could this work? :D
Flywheels are relatively cheap. Even if it would work, you would have more $ in the machine shop labor charges than the cost of a new flywheel.
gbeltran
I think all you will need is a new coupler, I didn't realize earlier that you have a COMPLETE engine setup, I don't see any reason that you can't just use the flywheel that's on the 350. What does the Mercuiser coupler you have look like? If it has a small circular base you wont be able to get it to work with the older flywheel, if it's one of those big triangular ones (and I'm not a Mercruiser expert so I don't know what years those are used) then it might just bolt to the 350 flywheel.
dan t.
the flywheel that is on the 350 matches the motor,leave it on there, the merc triangular coupler bolts to the flywheel the same as a pressure plate in a vehicle, remove the volvo flex plate or coupler and bolt it on
el_coqui
UPDATE
I've been away for a while, but because of all the help you guys gave me I needed to give you an update.
I'm not in the water yet, but hopefully I will be soon. The only thing I had to buy in order to complete the motor swap was the fly wheel. The 350 fly wheel was a small diameter, it was for a ten inch clutch plate. I got one for a 1977 camaro for a 11 1/4 inch cluch plate. Everything else transfer right over, I mean everything, starter, coupler, alt, all brackets, etc.
The motor is in and I'm dealing with a flooding carb and no ignition spark. I hot wire the ignition and was able to start it for a few seconds before I saw the carb flooding out. I started another thread about the carb, maybe I should of continued it here...maybe not since it doesn't relate to the engine swap.
Well...once I get the carb working corrected, I'll start with the ignition and hopefully no more problems. :D
THANKS ALL FOR YOUR HELP
