brodie123
- Joined
- May 4, 2008
- 279
Hi Everyone;
I rebuilt my Mercruiser 205 inline 4 - 165 hp inboard a year ago and she ran beautifully. (Dual engine in a 30 ft cabin cruiser)
That is until a line fell off the stern and wrapped the prop - luckily at low speed.
After that though, the dreaded "tap tap tap" noise.
I pulled the plug on cylinder 4 and the noise went away. The other 3 had no effect.
I pulled the engine and the rockers, lifters and rods all look fine.
I could not find any play on any piston - tapping lightly with a small mallet.
I removed the piston caps for cylinder 1-3 and all looked fine.
I removed the piston cap for cylinder 4 and the bearings 'popped' out rather than staying seated. Ooops, I forgot to check the torque on the piston cap bolts prior to removing to see if they stretched.
There is 'no' damage that I can find at all - not even a scrape.
I am assuming that the piston bolts stretched? Should I be looking for anything else?
When I re-assemble, new bearings is obvious. But what about the rod bolts? Do I replace?
Any guidance here is appreciated - I don't want to put it back in and hear tap tap tap. lol
thx!!!!
thx!!!!
