I have a 2014 Tohatsu 30 hp that would not start if the engine was too hot. Why is it too hot, I suspect the impeller may be missing a few blades so I've ordered a new one. What happened to me got to our fishing spot, shut the motor down, then went to start it about 10 minutes later. I would crank fine but would not fire. I popped off the hood and the engine felt pretty hot. So I paddled to the nearby marine and left the boat over night. I returned the next day and the motor fired up right away. Today, same thing. I used the motor out front of the cottage, then parked it. An hour later I went to leave and it wouldn't start again. It would just crank and not fire. I popped the hood off again and decided to splash water on the fuel pump area to cool it down. After 30 seconds, the motor fired right up. So to conclude this is obviously a temperature related issue of some sort. The ECU detects high heat and prevents the engine from starting to prevent damage. But WHY is it getting so hot to begin with? Thermostat? Impeller? Or some other problem?
