engine/transom mount compatibilty
phantomv170
I have an 89 Mariner 100hp. I was looking at getting an older 85hp Merc. The merc has a minnkota trim unit, while mine has the mariner trim.
Are the transom mounts standard from the older 85 merc( think its a 77) . Or would it be better, if possible even, to leave my mount and trim, and put the 85 merc onto my mount?
Chris1956
Honorary Supreme Mariner
The older Merc 850 would likely have a different bolt pattern than your 89 Mariner. I am not sure what the Minikota PTT unit has. Four 1/2" bolts in an upside-down trapezoid pattern is the std bolt pattern, and should be used on your Mariner.
I am not sure if the powerheads or midsections interchange on those motors, but several on this board should know.
