engine trouble 1965 110 hp chevy mercruiser
65holiday
have a 153 cid 4cyl chevy mercruiser 1965. bad valve seat ( or gone) in #4 exhaust. pulled water into #4 from manifold crack.working wtih machine shop and welder on repairs but need gaskets. have tried michmotorz for some and masonmarine but some are unavailable for manifold(carb) and some of the plate gaskets for the aluminum 1/4 " bolt variety manifold Engine s/n is 1825234 (1963-1966) I believe. any suggestions? I have some of the merc part numbers but not all. help! greg
P 0 P E Y E
Re: engine trouble 1965 110 hp chevy mercruiser
Have you tried your local Mercrusier dealer?
65holiday
thanks popeye, yes I have, they only have access to original parts...many are NLA. I have some of the orig part #'s and think I will try Delta Marine in Columbus Ohio again. Mick was very helpfull and sent accurate pictures of the manifold in question. Hope to hear from machine shop 7/15/09 re: the valve problem. Have a welder lined up to tig manifold based on valve situation. The manifold has 5 plates plus exhaust elbow. anyway thanks for the reply! Greg
65holiday
put to top....head is ok ...rebuilding it and have peeled manifold plate gasket (lower) off of plate and think I can make it. need aftermarket gasts though if possible...will try more calls... where can i get sheets of gasket material? at a boat dealer?
fishrdan
A good auto parts store like Napa or CarQuest will have gasket material. Try to find flat sheets as the rolled stuff is a pain since it wants to curl up.
A ball peen hammer is your friend for making gaskets, position gasket material over part and tap around the machined edges to cut through the gasket material.
65holiday
thanks fishrdan, i found soaking plate and gasket in water overnight allowed pretty good intact removal ( using razor blade scraper)for transfer to new material, have about 5 more to do on aluminum 5/16" bolt manifold... also found out I may have been able to switch heads and use updated manifold, head rework already in progress though.
novicetech
Bondo, just trying to help out a friend, I work with this guy and I dont know much about boats or motors from this era.
Gotcha,... But I don't see the Question,... It sounds like the OP has it under control....
Btw,... Updating it would have been the Easier route to go....
65holiday
back to top... whats the best way to clean the aluminum manifold parts?
65holiday
back to top. wow! marinepartsplus.com is awesome, found all but two of the nla gaskets!!!!! keep trudging ! thanks guys
65holiday
back top marine parts plus awesome .puttin the manifold in the dishwasher!yow!!!!!
65holiday
to the top, can I update to a newer manifold on that head The head was reworked and looks fabulous.Heck, I'll call michgan motors tommorow.
65holiday
exhaust elbow shot... any ideas on junkyard parts or retro-fitting to a newer manifold? who would I contact
woosterken
nice way to pad your posts bondo you don't either
65 holiday here is a salvage yard for old boats laniermarine.net
woosterken
can I update to a newer manifold on that head The head was reworked and looks fabulous.or retro-fitting to a newer manifold?
Ayuh,... Not that there won't be a few obstacles to overcome,...
You should be able to swap the Complete intake/ exhaust Manifolds,+ riser from a 120/ 140 up to around the Late 70s...
fishrdan
Have any pics of your head, manifold and exhaust elbow? From what I've seen there are 3 different head configurations used on the 4cyl GM marine engines, 1 with 2 combined exhaust ports instead of 4 separate exhaust ports, 1 with large intake and exhaust ports, latest version had small intake ports for fast intake velocity.
Your obstacles will be matching up the head/manifold port configurations and anchor points for the linkages, also check the carb bolt pattern as the newer Mercarb has a wider bolt pattern than the old Rochester 2bbl carb.
65holiday
top, thanks fishrdan! unbelievably I was able to find a salvage manifold complete within 10 mi of the house. It is the style with combined exhaust ports. the guy has 2 and i'm grabbin the other one too.Novicetech (I work with him) helped with head installation etc and I'm putting the rockers on today,planned on following clymer manual for this.thanks guys for all your help!
65holiday
guys, valve adjusting question. when adjusting the valves on the 110hp chevy 4 cylinder the forum here says to remove all end play at the valve and push rod and then go 3/4 turn tighter. the clymer manual says remove end play at the push rod but then that zero end play means you cant rotate push rod! then go 3/4 turn. I have zero end play (lash) and went 3/4 turn but i could rotate push rod prior to the 3/4 turn. want to make sure i get it right which is correct? thanks
