engine trouble 1965 110 hp chevy mercruiser
65holiday
Re: engine trouble 1965 110 hp chevy mercruiser
pushrod backlash zero end play or adjust so push rod wont rotate?
bigskiohio
both valves have to be closed.
fishrdan
Spin pushrod in between 2 fingers while holding it lightly and tighten rocker arm nut, when you feel the the pushrod grab, or change tension, you are at zero lash. There should be no up-down play. Socket pushing against the rocker arm could give a false reading so check it again once the socket is removed. I try to have the socket up on the nut a bit to avoid it binding anything. Atfer they are at zero lash, slowly tighten another 3/4 turn.
65holiday
thanks! theyre not real specific in the manuals,i"ll go that route.
