acdc96
Thread starter- Joined
- Apr 23, 2013
- 412
I'm tuneing my engine up for this coming spring. The boat hasn't been in the water for a couple years. The engine runs OK, needs some carb work. I just put in brand new bellows. I ordered water pump rebuild kit, new trim solenoid, and trim cylinder seal kit.
I have some questions.
1. Should I replace the exhuast manifold gaskets? That would include the manifold to block gasket and riser gasket. The exhaust does not leak.
2. My boat has power steering, what kind of fluid should I get? Is it regular car power steering fluid?
3. My trim cylinders don't leak, the retainer rings have came out for some reason. what's up with that?
4. Im gonna change the oil in the motor, will going through the dipstick be the best way to remove the oil? Or should I take the plug out of the oil pan? I've heard of people sending off their oil to have it analyzed, should I do that? If so who do I send it too?
I am a DIY guy and don't want to pay to have some mechanic $$$$ an hour to do simple engine work.
Engine: Mercruiser 260HP V8 Alpha one gen 1 drive. 1986 or 1987.
