jeffwhite22
Thread starter- Joined
- Jul 6, 2005
- 3
I have a 10hp '58 Johnson Seahorse. I have had it for a week now. When I first used it, it cranked and ran perfectly fine. The second time I took it out it would not crank at all. It would fire when choked but wouldn't do anything when not choked. Occasionally it would fire (sound as if it would when the choke was on), but never start. I figured I had flooded it. I took it out the next day and it did the same thing. For some reason, it will now crank and run when it is choked but die as soon as I take the choke off. The plugs seem as if they are in good shape. I did fill the gas up. Is there a chance I put too much or too little oil in it? Any help would be much appreciated.
