thestigmach1
Thread starter- Joined
- Mar 30, 2015
- 81
I recently built a 350 for my boat with agressive cam and intake. Ive done similar builds many times before. Intermittently it will not rev past idle. It just sits and makes a chugging sound. The tach drops to very low rpm even though I can hear the engine is not that low. Sometimes it runs great sometimes it does this. I cannot find any air leaks in the intake or carb. Seems to be worse when engine gets hot. I triple checked that all the wires are in the correct order. Im using a high energy msd coil. Had it running on muffs earlier and ran fine for nearly 30min at 2k rpm then took it to the lake finally for the first time this year and it pulled this mess again.
