Hi Folks,
Newbie here.
I cannot get my 87 90HP Johnson to start without carb cleaner, once it starts, it will run forever.
I know it isnt recommended to use the cleaner as it has no lubericant in it
I can wait for 30 mioniutes r so after t is started shut it down for an hour, and it will start back up.
If it sits for more than a few hours, I amback to the problem.
To start
prime the carb with the ball
turn key to on
count to 10
let it turn over
I usually wait for 30 to 60 seconds to give it a chance to start.
Even if I remove the cover, play witht he throttle manually while someone else turns her over, no dice.
Seems the only way to start is with the carb cleaner
Any suggestions would be GREATLY appreciated.
Thanks in advance !
Newbie here.
To start
turn key to on
count to 10
let it turn over
Thanks in advance !
