Engine won't shut off
Gerkin
Hi all. Hope everyone is having a great summer and lots of boating.
So this is a new one to me.
Twin rebuilt engines. (BBC 454s)
All new wiring, gauges switches. Basically everything is new.
When I fire the engines up, the Volt meter hangs around 12 until I give it a good rev of the throttle and then it jumps to the 13-14 range. When that happens, I turn the key to the off position and the engine will not shut down. I have to open the hatches and starve the engine to make it die. Also when I do turn the key to the off position the volt meter bounces all around between 12 and 14 like it is confused what is going on. Just like I am.
What is going on here? Where should I look?
Thank you for any and all help on this
Let's start with are the Motors Volvo Penta, Merc, Crusader, etc ??
Next you have a serial number?
ok, PCM will make it a bit harder to find wiring diagrams but will look
Moved thread
Gerkin
I have to assume wiring is wrong somewhere in the line. I will have to go out to the boat and then tell you where each wire is going
I'm having a hard time finding an actual wiring diagram for PCM. I can find the owners manual and a so called service manual but neither show a diagram.
Get a pic of the back of the key switch, I'm wondering if it uses the same wiring as Merc
Still nothing definite but think it would be same as Merc
Bt Doctur
How many wires are on the back of the alt? In most cases like this the diode in the alt is bad and backfeeding the ign system
kenny nunez
Take a close look at where the main battery cable is bolted to the solenoid on the starter. The battery cable could be contacting the bypass wire stud which will give a back feed . The wire may be black /purple.
Another possibility may be if you replaced the boost or slave solenoid with a automotive grounded base style could also give a back feed.
Gerkin
I believe it is a 1 wire alternator.
I will go out to the mooring tomorrow and report back what I find
Gerkin
So, I went out today to check it out.
From the key, (I) 1 wire (purple) goes to the ballast resistor. The other side of the ballast resistor goes to the neg on the coil.
1 10 gauge wire (orange) goes from key, all the way to the alternator. Also coming off the alternator has a black 10 gauge that is bolted to the block. Have to assume ground.
Also on back of Key, (B) 1 10 gauge wire goes to the starter solenoid in the same place the positive battery cable is connected.
Also back of the key (S) White goes to the neutral safety, which then goes to another solenoid bolted to the block near the engine circuit breaker
Which should go to "Pos" side of coil
Orange should not come from the Key, the (B) connection should be Red/White
As Bt Doctur mentioned in post 9, you should have more than 1 wire on the Alternator and a diode maybe shorted and back feeding. Look close at the ALT and how many wires are there?
Gerkin
Ok I will look closer to the alternator. I hope it is not bad. Had those rebuilt for a stupid amount of money. Its a tight fit in there with twin engines.
Sounds like I have some wiring issues. Unfortunately we had a "good" mechanic wire a lot of this boat and we had to let him go. Too many mistakes
Gerkin
Thank you for all your replies. Very helpful. Fixed the issue. You we right. The alternator should not have gone to the key. Rather, the starter solenoid. And I misspoke about the purple going to the neg on the coil. It was actually going to the positive.
