Engine won't start, ignition fuse blows
trevjack
Recentlypurchased '79 Grady White Gulfstream 205 with a 470Mercruiser 4cylinder. After putting recharged bateries in fired right up. Turned off engine and then went to re-start and only heard a click. Found the fuse blown that runs from the Key/ignition.
Have replaced 25 amp fuse three times and the same thing keeps happening.
An ideas what could be causing this.
Bt Doctur
Re: Engine won't start, ignition fuse blows
shorted slave solenoid??
Juniinc
With an ohm/multi meter, perform a continuity test between the tripping line & ground. maybe shorted to ground.
could be the random solenoid internal short as Bt said.
Be very careful of information given by me,,,
jerryjerry05
Sounds like the starter is dragging.If the cable connections are good and clean.Check the starter.J
trevjack
BT Doctur - right on! I finally got some time and checked a bunch of wires which looked good so decided to try and change the solenoid ($15 at the local NAPA).
Fired right up, also kicked on a dead bilge pump and light.
Should be ready to go. THANKS
