Engine won't start in neutral
DAF
I have a 2000 Evinrude FICHT RAM injection 150hp engine that won't start in neutral. It will start in gear. I bought the boat and engines in March 2011 and drove the boat 90 miles to the island I live on. I had an Evinrude mechanic check the engines before I bought it; everything seemed fine. The engines both started in neutral at the start of this long trip. After about 75 miles, one of the engines cut out and we couldn't get it started again, so came the rest of the way on only one engine. Since then it has not started in neutral. I live on a really small island in the Caribbean with no real access to trained mechanics unless we fly one out. I have disconnected the neutral switch but it made no difference. I have also been told it 'may' be the stator that needs replacing although I'm not sure about this as I don't understand why it would start in gear and run if the stator was gone. A new stator will cost around $500 to buy so I really don't want to buy it unless I know that this is the problem. I have had an Evinrude mechanic run a computer diagnostic on the engine - nothing came up. He was the one who suggested the stator but was not really sure if that was the issue. Unfortunately he was on island checking someone else's engines and didn't have much time to spend with mine. I really think this is a simple problem, anyone out there have any ideas???
Chris1956
Re: Engine won't start in neutral
Does the motor spin using the starter when in neutral, but not start, or does in not even spin?
The neutral switch you disconnected was on the motor shift linkage, or in the throttle control box?
DAF
The motor does spin when in neutral, but just won't start. I disconnected the neutral switch from the motor shift linkage.
Silvertip
The neutral start switch prevents the starter from engaging unless the lever is in neutral. It is the kill switch (the lanyard) that would allow the engine to spin but not start. I'd check the kill switch and wiring inside the control box. If you actually disconnected the neutral start switch the starter would not spin. If you intend (and apparently you do) work on this engine yourself you are strongly advised to obtain the factory service manual for this engine. It saves lots of time, potentially saves a ton of money, and lastly -- lots of guesswork and frustration.
davidvo68
Did you get your problem solved? My issue is the same as yours. I can start the engine in gear but not at neutral. Hope you solved yours.
David.-----That was likely fixed 11 years ago.-----Start a new thread.----Post model # and what the issue is.
