Engine
jthomas
I have a 1995 Sea Ray with a 4.3LX MerCruiser Engine. Engine seems to die when I try to accelerate. Have put in new fuel pump and new water filter and has not helped. Checked hoses for leaks and have not found any. Someone help???<br /><br />------------------<br />Thanks,<br /> Jamie
Bob_VT
Re: Engine
Seems to die???? Do you mean it bogs down and hesitates? Well I would check the accelerator pump in the carb. The possiblity exsists that the pump spring has gotten worn. Rebuild kits normally come with a new pump. Also check the engine timing. If the timing is not advancing properly it will also cause problems.
fone_man
Re: Engine
OK...<br /><br />95 4.3 (V6) Mercruiser???... Carb of F/Injected???<br /><br />I could care less what kind of boat it is... I need tech info to help... provide me some details & I will try to help...<br /><br />Awaiting your reply....<br /><br />fone_man
clanton
Re: Engine
The V6 have always had problem with exhaust manifold. If everything else check out, See www,boatered.com,and ask about manifold, I seen posting about different riser, from Merc cant remember where.
clanton
Re: Engine
jthomas
Re: Engine
Thanks for the help. Found out what it was.....Something tripped the main circut.
Walter
Re: Engine
Huh? Tripped the main circuit? I don't understand... What main circuit? I don't see how could it run at all..<br /><br />Walt
fone_man
Re: Engine
Hey Walt... What main circuit is he talking about??? He must be calling something... something else!!!<br /><br />Would be interesting to find out!!!
evin300
Re: Engine
Ya, last time my main circuit tripped I couldnt get on my puter! Sorry, couldnt help myself.
fone_man
Re: Engine
BINGO............<br /><br />You got me smilin late at nite... Evin(Merc)300!!!<br /><br />I guess what you grew up with & know sticks... Merc all the way!!! But my bro' thinks his Johnson hung the moon... won't have anything else...
