LilRedNeckGirl
Thread starter- Joined
- Jan 25, 2010
- 184
1985 wellcraft, GM 3.0 inline 4cyl. Issue affects BOTH engines.
Serviced @ rebuilt carbs, checked chokes, new dist cap, points, wires, rotor, plugs. Water seperators and small inline filters, fresh gas, ...
Start engines from dead cold, easy start. Idle fine. Temp reaches 160. [operating temp] shifts fine, throttle up normaly, engines [both] bog then stall. forget hole shots, thats a sure stall. they can be coaxed up and after 2000 rpm, they are fine, hammer down and here we go. other then the mentioned issue, engines run fine, good compression, no knocks or taps, no smoke, no vibration.
idle speed is steady 600 on both. both are affected between idle and 2000 rpm. carbs are clean and seemingly not the issue. fuel consumption, @ 30/35 gal apx on a weekend that see's apx 100 miles of travel with both engines running.
I was thinking the vacume /spark/timeing advance but these carbs dont have vac hookups.. Its got me stumped. water sports are on the menu this summer with the grand children moving back into my life. Gotta find/figure out the "Gremlin" and get this boat doing hole shots...
