Re: epoxy on vertical surface - to thicken or not?
Thanks again ladies and gents. I went ahead with the unthickened resin and 1 1/2 oz CSM today (before I had a chance to read the last 2 replys, lol). It seemed to work out well. Todays portion of the project simply entailed laying 2 segments of CSM, each about 5" x 15". Since they were so small, I simply rolled them up, dunked them in the epoxy I had mixed in a plastic bowl, and once they were completely soaked unrolled them, removed the excess resin, and applied them. I then went over them with a grooved roller and squeege to make sure there was no trapped air underneath. I did get some drips, but nothing serious - I just had to wipe it up every 15 minutes or so for the first hour until the resin firmed up.
The projects (I have two going on at once) are simply "fiberglass training projects" for me, for some practice before I get to my "real" project boat (if I ever get there). If they turn out well, great; if not, no big deal either. This is more about experimenting with and educating myself about various cloths, fillers, techniques, etc. I'm currently working on an 8' dinghy which has a few holes in it, as well as an old gutted Sea Doo hull that my buddy wants to use as a "trailer" of sorts behind his running Sea Doo. The Sea Doo hull needs to be patched in the areas where all the old thru-hulls went for water intake, drive shaft, exhaust, etc. so it will float on its own.
I elected to use CSM for a couple of areas on the dinghy which had holes, but were inaccessable from the inside. My thinking was that the mat would hold resin better than cloth without allowing it to run through the holes in the hull (into the inaccessable area) and would provide a solid surface to go over with the cloth. Now that I have a "sealed" substrate, I pland to sand much of the CSM off and apply a few layers of 6 oz cloth (since I have some leftover from a previous kayak project) to beef it up. After the cloth layers are complete, I have both microballoons and a fairing compound to experiment with for the faring step. I'm not really sure what the difference between them is, as they both look very similar when you take the lid off each bucket and look.
