chrishayes
Thread starter- Joined
- Apr 9, 2009
- 691
Guys, I finally got to fiberglass this weekend! It was MUCH better than grinding. I feel I did an excellent job on it too. 8 yards of 1708 and 15' of 8oz cloth tape and No air bubbles whatsoever. I will post an update in my thread soon.
ANyhow, on to my question, I have built the transom out of 2 peices of 3/4" ply and used thickened epoxy to join the two together along with screws every 6". Those screws were countersunk and filled with the PB. Now I am ready to install this chunk into the boat. Since I am using epoxy, is it ok to just use PB to hold it to the outer hull or should I use a layer of 8oz cloth to help with the bond? Does it matter?
Should I sand the epoxy surface that I put on both sides of the ply to seal it before clamping it to the hull?
Also, when I sat the finished piece in the boat there is a couple finger widths of space at the top center of the transom but the bottom and sides are butted against the hull. Is it going to create a problem if I clamp and screw this thing in to pull that gap closed? I am thinking that having a rotted transom may have allowed the hull to bow at the point that the motor hung on(150hp ob). What do you think?
