Equipment Placement on Transom
FBPirate95
Master Chief Petty Officer
Can you guys take a look at this photo and see if these are appropriate spots to place the equipment? I've looked at the directions for everything, and from my best guess this should work. But as always I'd like advice from those with some experience.
ezmobee
Re: Equipment Placement on Transom
You're gonna have to work on that pic a bit FB.
180shabah
As long as you don't have a reverse chine, it looks good. If you do just slide the tabs inboard a little.
CATransplant
Check the manual on your sonar for recommended placement of the transducer. Your spot may be too close to the turbulence from the prop.
ajgraz
Agreed. I'd put the transducer between the pitot tube and the starboard smart tab.
DukesFin
X3 - Better safe than sorry! I KNOW it will work better further out, but not so sure where you have it now (or plan to), so rather than have to fill holes and move it later, I'd do it now!
73Trihull
My manual says to stay a minimum of 12" from the outboard. Next to the speedo is where i put mine.
FBPirate95
Once again, thanks everyone! I'll follow ya'lls suggestion. But of course, if my fishing results are poor, I'm gonna blame all ya'll. LMAO.
