erikgreen
- Joined
- Jan 8, 2007
- 3,105
Well, I have a little bit of time today, so I thought I'd put up a teaser about my planned winter boat project.
A bit of background: I got my first boat in December '06, tried to fix it up, and ran out of steam. I then got a boat in better shape, and started fixing that one. I bought a third boat to get parts for the second, stripped it, and junked the hull. I just junked the hull for the first boat, so I'm down to one working boat, the repairs of which have been chronicled pretty well here. I have a bit of work to do on that one too, but it's mechanically sound, and I'll winterize and store for the winter soon.
But... I've had the first boat on the lakes (great) this summer, gotten hours on the water and learned what I like and don't like about it. It's basically a compromise between my desire to be able to handle the boat solo and my desire for enough space to sleep (uncomfortably) on board. It's ok for both of these, but it's really not great at either one.
My solution is going to be to finish fixing up the first boat (and use it next summer too) while I work on getting two more boats. The big one will be a displacement hull trawler or cruiser, with diesel engines, maybe 35 feet or larger, up to about 55-60 feet if I can find one that large for the price I can afford.
This thread is going to be about the smaller one, which is meant to be a boat light enough to tow easily, seaworthy enough for the great lakes and carrying a four pack of divers, big enough to let me run my sonar and tow the occasional tube, and small enough so I'm not straining to keep it under control all the time.
Here's the really controversial bit: I want exactly what I want, and the only way to get a perfect boat on my budget in my time frame is to build one from scratch
This is a board about restoration and BUILDING, right?
So, here's a plan view. Some of you will recognize this hull and be able to pull up pics and specs from elsewhere, but the thing to keep in mind is that this is only the basic hull. I'm going to modify it in a way that will make the original designer cringe
Specs are: 19 foot hull, epoxy/glass/plywood construction, 1900lbs displacement, 90-150 horse motor (I may use two 50s or so, dunno yet).
I'll be adding on to this thread when I start construction, which is probably going to be in about two months at this point. I have to clean out my build space (it's different from my other boat's build space) and install lighting and insulation there.
Erik
Erik
