guy48065
- Joined
- Aug 31, 2008
- 564
I just went thru this problem 2 weeks ago.
First problem was with a new radio I put in my 25yo freshwater bow rider. The new radio worked for a day, then started freezing on the startup logo, dropping Bluetooth connections, etc. After swapping in another radio the problem returned.
Then my tach joined the 'wonky' party.
I found when I directly connected the radio to the battery--bypassing the fuse block--it worked fine. On close inspection many of the blade fuses had a light film of chalky corrosion on them. I replaced the fuse block, all the fuses, and put new terminals on every wire. The clean power & ground connections fixed everything. Motor seems to run a bit smoother, too.
This flaky power problem did NOT show up on probing with a dmm... Voltage was normal and solid. Voltage drop from battery to radio was just a few millivolts. I got lucky and found I could get the radio to cut out if I gently touched the wire or the fuse for that circuit.
This boat has never been in salt but it's damp a lot and that's enough to cause corrosion.
