Error codes or service manuals
wavewhalen
Does anyone have a link to the Yamaha error codes or service manuals. I saw a link for service manuals on another forum, but the link ended up being for the assembly manuals.
Thanks
wavewhalen
Re: Error codes or service manuals
I'm looking for information on the 2006 Yamaha VX Deluxe. Appreciate any links or PDFs you can send. Thanks.
JUSTINTIME
13* Pulser coil 118 Electronic throttle system
13* Pulser coils 119 Electronic throttle system
15 Engine temp sensor 121 Electronic throttle system
18 Throttle position sensor 122 Electronic throttle system
19 Battery voltage 123 Electronic throttle system
22 Atmosphere pressure sensor 124 Throttle position sensor
23 Intake temp sensor 125 Throttle position sensor
24 Cam position sensor 126 Throttle position sensor
29 Intake press sensor 127 Throttle position sensor
47 Slant detection switch 128 Throttle position sensor
53 Exhaust manifold temp sensor 129 Electronic throttle system
54* Bypass valve motor 131 Accelerator position sensor
54* Stepping motor 132 Accelerator position sensor
55* Steering switch 133 Accelerator position sensor
55* Steering sensor 134 Accelerator position sensor
63 Throttle body 135 Accelerator position sensor
64 YPVS 136 Electronic throttle system
65 Ex. manifold water temp. sensor 137 Electronic throttle system
66 Stepping motor operation 1 138 Electronic throttle system
67 Stepping motor operation 2 139 Electronic throttle system
112 Electronic throttle system 141 Electronic throttle system
113 Electronic throttle system 142 Electronic throttle system
114 Electronic throttle system 143 Electronic throttle system
115 Electronic throttle system 144 Electronic throttle system
116 Electronic throttle system 145 Electronic throttle system
117 Electronic throttle system​
