Joshua Nichols
Thread starter- Joined
- Jun 29, 2009
- 1,431
Well was getting things lined out on the boat.. Turns out that noise I was hearing was my Y pipe rubbing on the exhaust upper.. Yeah it makes a horrible noise.. Sounds kinda like u joints.. Figured it wasn't the u joints after I fired up the engine with the outdrive off and still could hear it.. Took a while to figure this one out..
Anyhow.. I am pretty sure my ESA module is shot.. Checked the switch.. Working.. Looked over the wiring and everything looks to be in order.. I wouldn't even notice the thing wasn't working but I hit the switch and it worked then hit it again and it won't now.. Shifts in and outta gear no problem, but I think this ESA is too help shift this into gear not outta gear.. Not sure.. Sound like time to try a new unit? I don't really see away to troubleshoot it other than stick on a new one..
