mrsaundep
- Joined
- Jun 9, 2009
- 55
MCM 140, Serial number, 5568367
Good day,
Further to previous post July 11th, 2012, 01:09 PM...
I purchased the 3.0L Delco EST distributor kit from Michigan Motorz as recommended on above post by Don S.
I have finally received the parts from the States and got round to start the installation today and have a couple of questions please; I have removed old coil and distr, installed the new coil and 'distributor' mechanically.
Electrically I found that the old coil had TWO wires connected together onto the coil ?+? terminal;
- 1 purple/yellow - connected to the starter motor solenoid,
- 1 brown colour (but when I dug further into the harness it was actually a pink/purple colour) ? cant trace where it goes to as lost in the harness wiring.
I have checked the Battery voltage = it was 12.6VDC.
The Voltage on purple/yellow wire to the coil + (with Ignition key in the run position) = was 0.0 VDC!
The Voltage on brown (pink/purple under the harness) wire also connected to the coil + (with Ignition key in the run position) = was 11.4 VDC.
The Instructions from Michigan motorz only mention 1 wire purple/yellow. These instructions also state that the voltage to the EST coil ?should be 12V - battery voltage?, but that it must be more than 10.9 volts. I am getting 11.4V, but as stated my battery voltage is 12.6V. So I guess that a resistor must be fitted?
Now then, the Mercruiser manual#3 wiring diagram shows the purple/yellow wire between coil and starter motor, and a purple resistor wire. So I appear to have both these wires on the installation but I am confused as to why I have 0V on the purple/yellow wire and 11.4V on the purple resistor wire?
So, my questions are;
1). Which wire(s) of the existing purple/yellow @ 0.0V and purple wire @ 11.4V should I connect to the purple wire on the new EST pigtail plug to the coil?
2). Or, should I run a new cable direct to the coil to give full battery voltage @ 12.6V direct to the purple wire on the new EST pigtail plug to the coil? If I should run a new wire, where is the best source (location) to run the wire from?
3). Is the grey wire connected to the old distributor the tacho cable? (This is not shown on the engine wiring diagram I have from Manual #3).
I am quite tempted to experiment, but am a bit worried about blowing something up!! So I thought I would dig into the mass of experience on here yet again!
Many thanks in advance for your helpful replies...
Paul
Good day,
Paul
