Etec fuel pressure
wrench 3
Does anyone know what the fuel pressures should be on a etec 2007 60hp?
wrench 3
In case anyone is interested. I finally received the service manual today and the fuel pressure on the high side should be 20-30 psi on the larger engines and 18-32 psi on the 15-30 HP.
Chris1956
That sounds like the pressure of the low pressure fuel pump. I would guess the high pressure fuel pump would need to be 200PSI or so.
WernerF
Chris, the injection pressure would be that high, but there is no way to measure it. You can only measure the pressure at the injector inputs. 20...30psi is correct there.
wrench 3
Hay Werner, where were you a week ago when I needed that information?
Trouble is, the pressure is OK so now I have to get into the electronics. But at least I've got the book.
