metriccrescentwrench
- Joined
- Oct 22, 2007
- 2,598
Re: Ethanol Question
Well..... the factory manual for my 1990 Johnson 200 says that 87 octance gasoline with up to 10 percent ethanol is acceptable.
The problems you describe happen with there's a significant temperature drop, and a filter/separator would take care of that. It'll trap the ethanol/water phase in the bowl which you can visually detect and drain - problem solved.
, both OMC and Mercury do NOT recommend running ethanol fuel in their marine engines.
