Ethanol!
JimS123
Yeah, yeah THAT thread again. I have my opinions, but I just wanted to see what the general consensus is.
My problem has been with a Merc 3.5 HP 4-stroke. I knew going in that it had small jets and they recommend running the gas out after each use. So, I do. Also use stabil with every fillup. One of the problems is that she is only a kicker and gets very little use.
I had 8 trouble-free years. Last year she wouldn't start. My dealer rebuilt the carb and it ran ok. This year she started but even after 20 minutes running would not reach full rpm and eventually stalled and would not restart. My mechanic rebuilt the carb again and said it had green gunk inside.
Again this year I was chastised for not running E0. I have never run anything but E10 in EVERYTHING. My position is that the ethanol helps keep the carbs clean. As an example my 45 year old Pontiac Bonneville V8 has not needed a carb rebuild since we started using ethanol.
Now my caveat is.....provided that you take care of your equipment. All my stuff is kept in a dry secure garage and with a full tank.
So what say ye? Should I switch to E0 in this little guy?
Pmt133
E10 gets this almost sand like depositing if left to evaporate over and over in carbs. E0 develops a varnish like residue. Both aren't good.
My take has always been proper care of the fuel system results in very little issues. The majority of carb rebuilds I have done are because it wasn't used much. Anything driven regularly seems to last until the hard parts themselves wear out.
I don't mind either. If E0 is readily available, I'd use it in low use motors. Otherwise, E10 has never resulted me with a fuel system problem that wouldn't have also been there if using E0....
Scott06
Like you I run ethanol fuel and have few issues. Just due to convenience filling up I run ethanol free in the boat and generally e10 in the jetski. Have yet to a have fuel related issue with either But the fuel doesn’t hang around long, I only use stabil when going into winter storage.
given the little use it seems I would try running non ethanol in the kicker. May use a fuel system cleaner like Techron or sea foam. Obviously something is going on with the fuel supply for the kicker... did you clean the fuel system completely after the first carb rebuild? If not what ever plugged it the first time will just plug it again. My buddies Glastron rebuilt he carb got two good seasons out of it then stumbling again. His fuel tank had chit and water in it. Second time I was in the carb contents of fuel filter turned cloudy in a jar.
Clean the carb and tank
Ditch the stabil
Then run the motor more often and drain the fuel system after use.
Item 15 is the drain screw
Green crud is the ethanol gel created when the fuel evaporated
As opposed to brown crud when e0 evaporates.
dingbat
I’ve had zero issues with the machines (2 and 4 stroke) since I started stabilizing all fuels and mixes at purchase that are not intended for immediate use.
From a boating perspective, I rarely if ever fill the 92 gallon main tank. Typically keep a 1/4 tank in reserve. Then add only what I expect to use (20-25 gallons) to the tank at each use.
In mid-October, I start adding stabilizer to the boat and mower fuels in prep for winter storage.
Ayuh,.... I drive a diesel pickup, 'n the only gas I buy is for my 1963 Jeep, or my various small motors, chainsaws, etc, which are mixed with oil, 'n stabilized when bought,....
For many years, the only gas I buy is non-ethanol,.....
Back when I lived in NY, I bought gas from native american supplied retailers, which was always non-ethanol, 'n now I have several local choices,.....
dingbat
I'd hate to see what 100 octane costs on the water... 4 total stations in my state, not even worth the hassle.
Don’t trust that list.
Says the station next to my office has E0. I know for a fact it does not.
They have 87 and 93 on my lake and both are over 5 gal
Maybe it's one of those things that it use to but not now, no idea. There is 5 stations in my small town and only one has E0 and it's listed
Pmt133
NJ makes it very difficult to get E0 or E85 for the spicy cars. :cautious:
I've been all over the state and never seen E0... anywhere else it usually isn't too difficult to find.
Jeff J
I think this is the first time I have ever seen a claim that E10 helps keep a carb clean. My experience is exactly the opposite unless wanting to remove some water from a fuel system. The only fuel system problems I have had on my boat were E10 related.
I have been told premium doesn’t have alcohol. One of the local stations also had a sign out front advertising it. The only time I tried to verify it was at that station and it failed the test. However, all grades of fuel went through the same hose. I ran 5 gallons into my truck before testing so maybe I needed to pump ten.
100 octane is available at nearly every airport in the country. Just don’t put it in anything with a catalytic converter unless you want to plug up your exhaust system. Some airports also sell clean unleaded fuel.
KD4UPL
I only run E0 in the boat and small engines. It's readily available all over in VA including on the water.
At stations right now E10 is about $3.50 and E0 is about $4.20. Given E0 gives you more energy content and thus more range there's no good reason not to run it.
Mc Tool
There is no ethanol in any mainstream fuel here. One brand does sell E85 but not for general use but for racing . None of the 91 or 95 ron has ethanol . NPD sell 100plus ( still no ethanol ) which comes with anti corrosion additives and a stabiliser and is guaranteed to keep for 12 months in a sealed container.
Avgas here still has lead in it .
Used to be that if one needed high octane fuel you had to buy it from an airfield , then it became available from some fuel depots but you had to put it in a container ( not your vehicle )and sign a declaration stating it was for motorsport. Now we can buy 100 ron from most fuel stations. Good for hi comp motors .....I had a wee miscalculation 😁 when building my Capri motor and wound up with about 11:1 cr and it clatters like a diesel on 95 but runs beautiful on 100plus.
I run all my small motors and outboards on 100plus because it keeps better otherwise Id be buying a litre at a time ....like my big saw has had the same gas in its tank for a year now . I actually put a plain sticker on them and write the date the fuel was put in my small motors 🙂
dingbat
IDK…I’ve patronized that station since built. Would have stuck out if they offered E0 as there is not really a demand around here
This is the people’s republic of Maryland. Maryland only has one navigable freshwater lake in the State (3 hrs from the said station) and several counties have banned the use of gas powered lawn equipment outright. There is even a website that encourages people to upload pictures of “offenders” for prosecution.
Lou C
That’s a shame! Well here on Long Island they tried to ban power equipment too but the landscapers went to out local town board and the explained what the reality of that would be (greatly increased costs and having noisy diesel generators in the back of their pick ups to charge many many batteries). So far they have relented. I do have a battery blower and lawn mower and they are OK for small homeowner jobs no way for big properties or commercial. That’s the reality no matter what the greens or blue politicians want to be true!
In my experience ethanol cleans gas tanks but fouls small carbs….
dingbat
Fortunately, I live in an unregulated county and I'm exempt anyhow given my AG Preservation status .
Have you looked at the commercial battery powered lawn equipment lately?
The equipment and its supporting infrastructure are expensive, but performance is impressive.
there is a large landscaping company about a mile down the road from where I live. Each truck has 6 people on them, 4 zero-turns, 4 back-pack blowers, 6 trimmers, 4 hedge trimmers, a rack of rakes, shovels, etc. behind the headache rack is a 500 gallon fuel tank. They must have 40 trucks with dump trailers. I asked them about diesel or propane or battery. the guy I talked to said batteries didnt last long enough and propane and diesels both have issues, none of them survive. The gas motors last about 2-3 years
When I worked for one of the Lawn and Garden equipment manufacturers, Electric was in its infancy. our commercial products were about 30% propane, 30% diesel, and 40% gas. the battery powered product was consumer only.
we had test fleets in Miami Dade county and cutting Sebring year-round.
I would love to see test data on todays electric powered equipment
the issues we ran into were E10 was actually being tested as E15-E20 in many of the southern states, which put much of the outdoor power motors into an overheat and melt-down situation. (there is now a sticker on them saying E10 max). The Natural Gas motors were conversions, and the regulators tended to ice up.
