Ethnoal Treatment
fishdan
1995 mecury force 70 hp . purchased this outboard about a year ago all the gas lines had to be replaced they were all soft .carb had to be cleaned . Runs great now. I don't think it has ever had any kind of ethnoal treatment in the fuel. Should i use an ethnoal treatment in the fuel and how often.
cbercaw
Re: Ethnoal Treatment
I use Stabil at every fill up nowadays..I also recommend installing a fuel-water separating filter somewhere between the primer bulb and fuel pump.. This should help with any ethanol problems and will keep your fuel clean.
j_k_bisson
Yes the water filter and fuel separator will help tons. Just remember to keep a spare filter on the boat. SO when it get full, normally while running, you can change it. Seirra sells a kit for around $30. Comes with two filters. Well worth the money.
TMALEGA
Do you guys have a link for that seperator also is it for a multifit setup or specific per motor? Thanks not trying to hyjack the thread.
j_k_bisson
Their are a couple different one out on the market. But they all do the same thing. The difference is the threads on the filters are made to a specific branded filter. Like the two them I know of is the merc one, big threads, and the Johnson/Evinrude, smaller threads. Also depending oo your HP rating the size of filter. Lower HP do not need the same size element in the filter as the big boys 150HP +. Best to look right here is you want to do your research. They sell them.
I would pick a serria or other aftermarket kit, they are cheaper and do the same thing. Just pick a filter style (merc, Johnson, etc) of the dealer that is closest to you. I think only two it three companies make these filters anyways....
