Michaela521
Thread starter- Joined
- Nov 29, 2005
- 6
Winterizing my boat. I just messed up. They say in the instruction manual to fill the fuel tanks full inorder to prevent condensation in the fuel tanks well I just accidentally filled it with 10 percent ethanol solution of fuel. The boat can run on the stuff but in the winterizing section of the manual it says that if fuel with alcohol in it is used the tanks should be drained as low as possible and fuel stabilizer used in the rest of the fuel leftover.
Is it really necessary to have to drain the fuel tanks like they say to do.
Also even if the answer is yes or no how do you siphon out the fuel tank well. I keep on sticking a hose in it and suck but only alittle comes out and the siphon stops. Doesn't work for some reason.
