Re: Ethonol-hows it hurt??
This is an excellent thumbnail from Canadian Yachting magazine and is available on line, so I believe that as long as they are credited, this is OK to post.
If not....I guess it will be pulled by a Mod and i'll get a 2x4 across the back of the head....
In both California and now in Florida, class action suits have been launched against gasoline companies alleging that they knowingly sold gasoline to boaters containing ethanol and that the ethanol would attack and damage the fibreglass fuel tanks in older boats. ?I would estimate that 90% of our service calls this summer related to fuel system problems of one kind or another,? I was told by Shawn Ireland at Lakeline Lodge and Marina, a Yamaha dealer and the only service facility on Charleston Lake in Athens, Ontario. I was talking to Shawn because my own little Whaler was disabled twice during the summer and, in both cases, a sticking needle valve in the 20 horsepower outboard had to be freed up. Then, the engine ran perfectly. The problems occurred after the boat had not been run in a week or longer. Probably, old gum or varnish was being dislodged by the solvent effects of the ethanol and dispersants also used in the fuel.
As we all haul our boats out and store them for the long winter, it?s certainly worthwhile to revisit the ethanol issue because things seem to be getting worse, not better.
We went to several of the top tech experts on this matter and we will share with you their best recommendations.
But first, we need to better understand the problem.
Tetraethyl lead was long used as an octane booster in gasoline but has been banned due to environmental problems. To replace that lost octane boost, oxygenated fuels were introduced and they usually contain either ethyl alcohol (ethanol) or methyltertiary-butyl-ether (MTBE). MTBE, too, raised environmental concerns so now ethanol has become the commonplace solution. Remember: Gasoline is formulated for your car or truck ? NOT for marine use.
Your vehicle burns a tank of fuel in a short period of time and vehicles have long been equipped with closed fuel systems that minimize evaporation and deliver fuel under pressure to fuel injectors. Fuel dispersants like detergent are added to help keep fuel injector nozzles clean. Little air enters the system.
Your boat is completely opposite; marine fuel systems are vented to the air because fuel must be drawn into the engine under a vacuum. It?s a safety feature. Should a hose come loose or the fuel system develop a leak, gasoline stops running. Otherwise, you could find yourself at the helm of a 36-foot hibatchi!
We can divide the ethanol fuel problems into two general areas: operating problems and tank problems.
The operating problems seem to come from gum, varnish and debris from fuel system hoses and parts that the ethanol has attacked. The most dramatic operating problem occurs when a blob of water and ethanol gets sucked into the carburetor, causing the engine to stop or stall. These blobs are a result of ?phase separation?.
Since ethanol and water readily dissolve in each other, when ethanol is used as an additive in gasoline, water will actually dissolve in the blended fuel to a much greater extent than in conventional gasoline. When the water reaches the maximum amount that the gasoline blend can dissolve, any additional water will separate from the gasoline.
The amount of water required (in percent of the total volume) for this phase separation to take place varies with temperature, but as an example, at 60 degrees F, water can be absorbed by a blend of 90% gasoline and 10% ethanol up to a content of 0.5 volume percent before it will phase separate. This means that approximately 3.8 teaspoons of water can be dissolved per gallon of the fuel before the water will begin to phase separate.
We realize that many Canadian Yachting readers have diesel engines in your sail and powerboats but the ethanol problem affects you if you have a dinghy or tender with a small outboard. Actually, those engines are more exposed to the ethanol issue because most dinghies are stored for long periods of time between uses.
Things get worse again if that little engine is a key part of your safety gear.
Water can enter ethanol-enhanced gasoline either directly (like rain water running off and splashing into a fuel vent ? think of vented cap on a portable 5-gallon fuel tank) or through moisture being absorbed from the air, especially during daily temperature changes when condensation occurs.
To get more than 3.8 teaspoons into the bottom gallon of fuel in your outboard?s portable tank might not take many cool fall nights.
Water as a separate phase, can have a major effect on two-stroke outboard engines because when the ethanol bonds with the water and drops out of the gasoline, the effective octane rating is decreased. Also, in the case of two-stroke engines, this water-ethanol phase will compete with the blended oil for bonding to the metal engine parts. Therefore, the engine will not have enough lubrication and engine damage may result.
In the case of four-stroke gasoline engines, the water-ethanol phase may combust in the engine. This combustion can be damaging to the engine because the water ethanol phase creates a leaner combustion mixture (i.e., air to fuel ratio is higher than ideal). Leaner mixtures tend to combust at higher temperatures and can damage engines, particularly those without sensors to calibrate air to fuel ratios.
So What Do You Do?
? Check with your marina or gasoline retailer. Some retailers, like Ontario area Shell stations sell Shell V-Power Premium and the pump is clearly marked ?Contains No Ethanol?. If you can be sure your fuel has no ethanol, you have no problem.
? If your boat has a fiberglass fuel tank; ethanol is known to chemically react with many fibreglass fuel tanks. They can deteriorate and potentially fail causing both serious engine damage and potential fuel leaks. Unless your boat's manufacturer can confirm that your fibreglass tank was built to withstand ethanol, over the winter, replace the tank with a non-reactive material such as aluminum.
? Always use fuel stabilizer. For any stored gasoline, it's important to add a stabilizer. Also, several engine manufacturers now recommend adding a ?maintenance? level of stabilizer in every tank. However, stabilizers do not prevent phase separation. Once it occurs, additives and water separators can't help. The only remedy is to have the gas and ethanol/water professionally removed from the tank.
? Before storage, run your boat for a time on stabilized fuel to best ensure that fresh, stable fuel is all that remains in the system over the winter.
? For boats with built-in fuel tanks, if possible, professionally drain and clean the tanks completely. We realize this is highly impractical though, so alternatively, add stabilizer and then almost fill the tank, leaving it with just a little room for expansion. A tank that is almost full limits the flow of air into and out of the vent, which reduces the chance of fluctuating temperatures adding condensation (water) to the fuel and thereby reducing chances of phase separation.
? If you have (or can change to) portable 5-gallon tanks, any unmixed gas (without 2-cycle oil) remaining may be carefully poured into your automobile gas tank and used. If you must store gas over the winter, keep the tank out of the sun and in a well-ventilated area away from ignition sources, keeping in mind that gasoline fumes are heavier than air.
? For all marine gasoline tanks, never try to plug up a fuel tank vent to prevent moist air from entering a tank. Without room to expand, the additional pressure could rupture fuel system components. Don?t block the vent with shrink wrap!
