Evenrude 100 starting problems
Maseikos
I have a 1979 100 hp Evenrude on my 1996 Suntracker 30' .. When I try to start the boat at the ramp.... it will not start... it has two fully charged batteries... the ignition switch needs to be pushed in and then turned... I get only a clicking sound from the outboard motor.... sounds like the bendix gear is trying to engage the moter... it takes multiple times clicking the switch to get the motor to finally crank and then start... after the motor is warmed up and driven for a few minutes .... it starts first time everytime.... Hate this problem at the launch ramp..... can you help me.....
HighTrim
Re: Evenrude 100 starting problems
Welcome to iboats. Sure does sound like a battery related problem. Are you sure your batteries are FULLY charged, up to 12.65 volts? Load tested? If so, check all wiring and related connections. Dont just look at them, take them fully off, sand them, make them shine, then reconnect tightly. Check wiring for any buldges or nicks, abrasions, etc... Most of these problems are wiring/connection related.
On another note, what is your starting procedure. Refer to this thread, and let us know what you find. Good luck.
http://forums.iboats.com/showthread.php?t=225510
D
DJ
Guest
Common issue.
1. Unhook the battery(s).
2. Remove the negative (ground-black) battery lead from the engine block.
3. Clean the bolt, threads and wire end ring.
4. Reinstall.
5. Go.
tashasdaddy
90% of starter problems are bad connections. remove and clean both ends of the battery cables, so that they are shiney, also the cable from the solenoid to starter. check for nicks in the cables. and make sure the connectors are on the wire good. the cable tend to corrode from the inside out, if nicked, corroded wires, and connections, heat up and cause resistance to the follow of electricity, thus the starter doesn't get enough. you can also take jumper cable pos battery post to large post on starter. with a good connection, the engine should spin. then if the starter is good clean everything and retest. then trouble shoot solenoid. starters can be rebuit at a starter/alternator shop, much cheaper than a new one.
also have the battery load tested at the auto parts store, free, i've had new batteries go bad
Maseikos
Thanks for your reply and the others that have taken the time to respond to my delema........ I have checked alll the contacts... the batterys are new and fully charged... I am in the process of checking the starter and selinoid... but am not a mechanic..... since there is a clicking at the motor I assume that there is some power getting to the starter but not enough to make it work..... any other opinions......
Maseikos
Thanks for your input...... the batterys are new fully charged.... I have checked all connectors and they are shiny and snug..... I turn the batterys on ..... it has two batteries.... with a selector switch..... I started with one battery and it did not work and then put it to two.... engaging both batteries.. I pumped the bulb.... to the outboard.... to get the gas to it... pushed the key in..... and then turned it as directed on the dash...... nothing... put a jumper battery on the batterys..... nothing..... kept turning the key.... over and over and over.... finally got the motor to turn over..... took a while and finally started..... (think the bad starting was from the wrong oil/gas mixture) which I corrected.... however it did turn over and finally started..... and the issue of it starting every time when it is warm and running does make one think it is a low battery... issue however...... they are fully charged batteries.... just put into the boat off of the charger..... and the connections are good...... I am perplexed...... thanks for any suggestions
Silvertip
Honorary Supreme Mariner
The click you are hearing is the solenoid engaging. The solenoid is like a great big key switch. Since the key switch would fry if had to carry the large amount of current the starter draws, the key switch activates the solenoid. The solenoid then switches the high current load to the starter. So just because the solenoid is clicking, does not mean it is passing current to the starter. So -- attach one end of a standard auto jumper cable to the positive post of the battery. Touch the other end directly to the large post on the starter. If the starter spins - the solenoid is the issue. If it doesn't connect the second jumper cable between the negative terminal on the battery and a good ground on the engine (an unpainted bolt or a metal bracket). Now touch the positive cable to the starter again. If it goes now, you still have a cable problem but you proved the starter is OK. Starters are rarely the problem. Cables and solenoids are generally the issue.
John Lapic
I believe Silvertip is spot on. Starting problems are generally tied to bad connections or a solenoid. I have work on a fair number or cars with starting problems similar to yours. If connections are clean and tight, the solenoid is the usual culprit. After time the solenoid can develop a "flat" spot. Ocassionally when you attempt to start it, the flat spot will not engage the solenoid and, along with it, the starter. After a few clicks of the ignition, you get past the flat spot and it starts. I have found that if it will not start, a light tap on the solenoid with a hammer will often correct the problem - temporarily. A new solenoid should correct the problem.
Lakester
hello maseikos, silvertip and all:
good tips!!
silvertip you stated:
"The solenoid then switches the high current load to the starter."
while i am sure the thot here is clear, imo... it is not correctly stated. there is no high current load present prior to engaging the solenoid. there is only high current [cold cranking amps] ~potential~. the solenoid only closes a path for the high amp potential to pass all its electrons from battery thru the main cables to the starter to energize the armature into rotating via the repelling magnet forces between fields and armature... where the high amp load exists. it is not high current load as it is only 12-volts. this is how i understand it. :)
several days ago, i redid my starter on my "gotta love 'er", had her for 15 years now, 83 chevy van. thru the years it has operated flawlessly, however of late... it would sometimes do nothing on the key. i did note some hestiation to its cranking when ignition key engaged at times. told me solenoid internal contacts for high amps may be corroded due to use. hey, 800 amps takes it toll eventurally. :eek: when it went dead, a screwdriver across the bat HOT side of solenoid to S 14 guage wire [maybe 12 guage] made starter engage and it was ok for a while. but i decided enuff was enuff. so i dropped it and went thru it, pulling the armature out of the brush(s). the bendix bellcrank ball was almost gone due to wear so i pulled the bellcrank and reversed it. now the bellcrank ball is like new. i also blew out windings, 600d the commutator and greased the shaft bushings. i like antiseize so i tweaked in some here n there on metal to metal sliding and rotating parts. the bendix slides back n forth and there are several items that grease helps down in there. i also put a very light coating of grease on the inside of the solenoid plunger cylinder and dressed its sharp edge on the front side due to some wear in the solenoid cylinder.
remembering the iboats tips on electrical connections i cleaned to BRITE all solenoid internal and external contact items, repaired a weak wire from solenoid (ezily broke when taking solenoid apart] just reversed to the other side the upper solenoid high amp terminal... and recleaned to BRITE all electrical wire terminals that go to bat side of solenoid and S terminal. i also broke both bat terminal connections and cleaned and reconnected. dint just tighten but took loose, cleaned and then retightened. i had - grnd off before i started project. i cleaned starter bolts and even put grease and some anti seize on threads and alignment knearls. then i tested my labors. the starter hit and cranked like a diesel locomotive. perfect! and much faster and if a starter can be quiet... it was quieter, too. sweet and it had a NEW attitude, too. a lot of work i must admit. and the next day i learned at auto parts store a rebuilt complete with new solenoid was only $39.95, :rolleyes: but i had done my own. i doubt they would have done the custom grease tweak i did, and well... it was a fun project. :p the wire repair was quiet a challenge. and i had to roll single wire to tiny coils off end of small round file tip to slide on broken end, then solder and do other end, too same way. i did not some internal starter items that had seen their full service life and brushes quite worn down. so i prob will just get the $39.95 starter if and when my starter opps 'out'. but i will take the new one apart and tweak it as to a custom lube. :)
so if this starting problem was mine, i would:
a) as stated, use the two jumper technique to see it u can bypass solenoid. and the cable/wire connection advice. also to ensure a really good direct ground tween bat and engine. additionally i would also:
b) try to engage starter no load. that is spark plugs out and grounded. i would listen to it both ways, too.
c) based on age, u may have broken, bad or weak [worn down] brushes. you may have other weak wires [partially cracked in two] in system. you may have corrosion on commutator. and/or carbon dust in and on the armature caused by brush wear. when i did my starter i blew it all out and the black dust flew everywhere. [dont breathe this stuff, protect eyes]
d) if everything checks out internally and externally, then suspect the solenoid. while i am exp'd in FOMOCO/GM automotive starters and solenoids, i am not sameO on marine stuff. so i do not know if solenoid can be taken apart as an automotive solenoid can. but their systems and designs are bascially the same. given that there are no component or electrical integrity problems any starter can be made to work.
e) and as a last result: if u are not willing to take apart ur starter i would be willing to take a look at it for you. no charge! if the solenoid can be disassembled i will go thru that, too. there is a starter shop just up the road from me and if i cant get it to work fine, then i can take it to them and see if armature is shorted, etc or? i know the owner. i have seen starters with one shorted circuit in field and or commutator. it would not turn over when a brush on that one bar. but hitting solenoid sev times got it to rotate a tweak and eventually it then turned. but, my bet is a good cleaning, service and assurance that you have solid voltage and amps to armature will make it crank nicely... first time; every time!!
i also use dielectric grease on all my electrical connections. its avail in tube or spray can. permatex makes a small tube. autozone carries it. $3.99. will do many connections as it goes on thin. also moisture proofs the ternminals, etc. and aids in electron transfer... an important element in any electrical system. i would also inspect the bat, solenoid and starter cable ends. tweak with electrical pliers and ensure the metal to braided wire to connector is tight. most can usually be tightened a bit more this way. id carefully clean all terminal ends... wire braids. and air blow clean. then tighten.
also consider the library. they should have books on starters and solenoids to study. i have read some and they explain it all well.
well, that is what i would do. and plan to do to my Lakester Special in the new year. the tips here on iboats are very good! and so helpful, too. hope my inputs here can be of value, as well.
regards in any event,
lakester
Lakester
hello:
both conditions could be present as both together. or solenoid. solenoid and bendix is louder than just solenoid only when engaged. my exp has shown me that if the solenoid engages... and pulls the bendix gear into ring gear it does one of two things when wont crank. if just click click is the result of the solenoid and/or the bendix working together. but when those two work together and the bendix gear has slid into the starter ring gear... and the starter is in good condition, but with low bat power connections or specific gravity... it then goes... errummph! and stops. or ermp ermp, erruummph! as in all components ok tries to crank, gets one or two pistons up n down... but bat power too low. so click click sounds like solenoid working, and bendix maybe, too... but starter dead. so i would remove cover and determine if bendix is working or not. ?? if not, then solenoid is. for something is making a click click :) doubt it is arcing... lol ;) but if the bendix gear also slid into the ring teeth, but no crank, then id suspect armature, field or brushes or related components inside starter.
regards
lakester
Maseikos
Thanks to you and the others who have posted to help me in my hour of need..... I will try all the soultions suggested and get back to you all with the results..... Thanks again John
