Re: Everyone's Favorite Word "Pitot" (Speedometer Question)
Hello all,
I saw some posts near the beginning comparing this system to an aircraft system. An aircraft has both a static (ambient) and Pitot (total pressure) port, but the two are only used together in one system, the airspeed indicator. This is only to compensate for large changes in altitude. As the altitude increases the density decreases, the pitot input must be compensated for that, and it uses the static to do that. the pressure in the Pitot tube at 200 Kts at sea level would be greater than 200 Kts at 10,000 ft.
Water is technically non compressible, so it is the kinetic energy of the water that you are using to compress the air in the tube leading to or in the instrument. The system on a boat does not compensate for ambient water pressure so it does not have a static port.
Peter
