Evibryde 40 hp 1997 clutch dog replace.
raczekp1
Motor -Evinrude 40 hp, 2 stroke, 1997
i need to replace clutch dog. how to tahe out shifter and 3 detent bals, and how to put it back?
boobie
Get a OMC Factory Service Manual. Ken Cook .com Milwaukee, WI.
Faztbullet
Why are you replacing??? If jumpimg out of gear will need gear replacement also.
Proof that these gearcases are not considered robust / strong.------Fairly common for those to break.-----Surely there must be other damage here.----Bearings full of metal bits ?
raczekp1
some metal bits-parts inside, spring (holding secure botl ) demage, some demage on gears.
Faztbullet
What type of boat and usage.. Will not hold up under a heavy boat ,toon or tube/sking...PM me for gear replacement info....all gears and dog $219 OEM list over $1000
raczekp1
i olready bought all parts but first i'm looking for info how to instal clutch dog and avoid vaste of time and flustration
You need a " special " tool.----Suggested in the manual I have.-----7.1 mm diameter.-----75 mm long----and a 20 degree angle ground on one end to go about 1.5 cm up the side..----So step # 1 is to make the tool.
Sorry----I have a bunch of those lower units apart and some that need to come apart.------Easy to work on.-----My camera work is not very good.
I believe you should take the propshaft / shift plunger apart.------In my humble opinion you could then see what you need to make.---Sorry.-----I have a few of these with clutch dogs that need to come off.-----Not hard to make this tool !!
