Tacklewasher
- Joined
- Sep 18, 2002
- 1,588
So I'm getting close to getting the speed I think I chould out of this combination, but I'm thinking I should be able to get a bit more. But it was only recently I was running on 4 cylinders.
Was out yesterday and, as the fish weren't biting, I went for a couple of speed runs.
I've got a 13X19 Stainless prop on right now. The boat (on the trailer) weighs out at 2400 lbs. Single axle trailer but a heavy sucker so I honestly think the boat is under 2000. Add me (260ish) and the kicker (80ish) and I'm still under 2500 for the boat.
Max speed was 36.5 mph (by GPS) at about 5200 RPM. That's giving me a slip of 22%
Cruising at 3200 RPM, I got about 26 mph. That's about 10% slip.
Raising the motor doesn't seem to be an option as I ventilate if I make even a slow turn.
My other prop (which does not have a pitch marked on it) gets me 32.5 at about 5800. If I assume the same 22% slip, then that prop must be a 15.
I've run a bunch of seafoam through. In fact, when I was down under a 1/4 tank yeaterday, I added a 1/2 can of seafoam and ran till I could tell the pickup was sucking air. Filled the tank back up and continued running. Didn't change performance.
So, should I be happy or can I get an extra 3-4 mph by tweaking the engine some? Is the 22% slip at wot an issue?
